Question about Kal Equipment Battery Tester - KAL Equipment
We have a kal 8300 battery tester will not power up when we hook it up
2 Suggested Answers
SOURCE:
gotgeek2
  • 565 Answers
SOURCE: i need an instruction manual for a kal model 4260
I'll tell ya, it sure took some digging to find that one. Evidently KAL Equipment was acquired by Actron.
http://www.actron.com/media/usermanuals/KAL4260_0002-000-2374%20PW_Battery%20Load%20Tester_MNL_Eng.pdf
Posted on Feb 24, 2009
How do i hook up monitors to peavey 8300 mixer
Make sure main monitor switch is pressed in, look at back of unit, the speaker jack labeled main/monitor is now monitor output, you may use 2 8 ohm speakers, use controls on front labeled monitors.
Jun 27, 2012 | Peavey XR 8300 8 Channel Powered Mixer
My car is showing no signs of any electrical power
Check the battery cables from the battery to the main fuse block and to the starter and all the grounds. Have you tested the battery to make sure it has a charge?
Apr 05, 2011 | 2007 Chevrolet Monte Carlo
1997 gmc sierra battery wont stay charged. Alternator and battery have been tested. What else could it be...fuseible link. If so where do I find it?
I suggest you hook up 12 V digital multitester to the battery running & get your voltage. Next stop the truck & get the voltage leaving it connected & you should see the voltage steadily dropping. Then, take off the Negative cable & hook up the tester again to the 2 post of the battery & see if the voltage drops as before, or has stabilized. That will tell you if the truck is draining the battery for sure of if you have a bad cell. If it is the truck, you will need to go through troubleshooting the entire vehicle by eliiminating all use of current and gradually hooking things back up. IE: disconnect main fuses/breakers & see what happens on the tester. Then start connecting 1 item at a time & see what is requiring power or if you have a short. You should eventually find the culprit even if you have to remove fuses and test each time. An additional tester that test amperes without penetrating the wiring is helpful in finding the drain. Normally in the auto-parts stores. I just lay mine over the wiring & follow the voltage until I find the wiring leading to the one using the power or that is shorted. Good Luck.
Jan 27, 2010 | 1997 GMC Sierra
I need an instruction manual for a kal model 4260 battery tester.
Feb 20, 2009 | Kal Equipment Battery Tester - KAL...
Sanyo SCP-8300
I'd suggest a new battery, if money is no problem but otherwise, if you have a volt-meter of some kind, you could read the voltage output of the charger and compare that to what it says it should be in the input-output list usually printed on the underside. If it's fine, I'd try carefully cleaning the phone's battery and charger contacts with a small amount of rubbing alchohol and some cotton swabs or tooth-picks lightly wrapped in toilet or tissue paper. If it still refuses to work, you could see if a sales-clerk at your local phone store would let you try a new battery to see if it would work. Otherwise, you could attempt internal repair/cleaning like I outlined here- keys won't work on sanyo mm 8300 phone.
Hope this helps, TechnoWolfy.
Oct 09, 2007 | Sanyo MM-8300
Kal Equipment Battery Tester - KAL Equipment Logo
128 people viewed this question
Top Kal Equipment Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Kal Equipment Measuring Tool and Sensor Expert? Answer questions, earn points and help others
