Question about KitchenAid Microwave Ovens
I have a Kitchenaid Dishwasher model kuds01fkss0, serial # fl3202898. The machine will start and run on the wash cycle continuously until the cancel button is pushed. I ordered the control card #8528172 and received the replacement card for this assembly, but on connector #1 the Y circuit has been removed and the washer will only run in wash for 10 min and the machine goes dead. Is their a connection mod to used the replacement card or is this machine "toast" Thanks Shep Beyland
    Habit-Forming:
    New Friend:
  • 28 Answers
Posted on May 21, 2017
3 Suggested Answers
6ya staff
SOURCE:
vetteman3002
Rodney Clark
  • 2299 Answers
SOURCE: whirlpool dishwasher, quiet partner 1,
If you can tell what cycle it is in, then it will be a lot easier to troubleshoot. I would suggest calling the 800 number in the manual and making Whirlpool pay for the repair. If the dishwasher is only 3 months old, then they will send a tech out to fix the dishwasher free of charge.
Posted on Jan 15, 2011
richroth
Richard Roth
  • 9472 Answers
Based on your symptom and details there could be something jammed in the chopper assembly or it could be the wash motor bearings causing it to stop the wash cycle and drain. I added some information and instructions in the image below if you would like to check the chopper blade area for any hard objects. You may have to replace the wash pump motor if no objects in the chopper blade. NOTE: Disconnect the dishwasher from the power supply if you're going to have to remove and replace the wash motor.
Posted on Jan 16, 2011
My Kitchenaid microwave model YKCMS1555RSS-1 continues to run. The microwave will only stop once the door is open or the unit is unplugged. Any ideas what this could be?
One of your three door switches is bad. They are cheap. replace them all. Careful some are normally open and some are normally closed. Don't get them confused or you will get other symptoms like a blown fuse
Dec 30, 2014 | KitchenAid Microwave Ovens
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
Ignitors continue to pop altho all four knobs are in off position Kitchenaid gas stove top Model #KGCT305X Serial #XB2806974 ir X52606974
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 21, 2011 | Microwave Ovens
Model KCMS1555R KitchenAid Microwave Oven turntable continues to operate even when the door is open. It seems to work otherwise. I disconnected it from the power hopping it would reset but that did not...
This is an extremely dangerous situation, if the microwave oven is running with the door open it means the safety interlock switches are not working the way they were designed to, and needs to be checked out for safety reasons. I recommend unplugging the device and not use it until it has been checked by a qualified technician.
Mar 27, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Kitchen aid microwave is locked
Touch and hold cancel/off button until unlock appears on the display.
Jun 21, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KitchenAid kemc308kss0 Micro/Oven Combo Microwave: At the end of any cycle there is a four-tone beep that will continue to beep until KINGDOM COME until you either a. open the door b. press cancel. That is...
From page 7 of your owner's manual:
All Tones (combination oven models only)
All of the above tones are preset on, but can be turned off.
To Turn Off/On: Touch and hold STOP TIME for 5 seconds. A
tone will sound and “Snd oFF” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd on.”
Tone Volume
The volume is preset at high, but can be changed to low.
To Change: Touch and hold the number pad “7” for 5 seconds. A
tone will sound and “Snd Lo” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd HI.”
REMINDER TONES
The Timer and Timed Cooking reminder tones are preset on, but
can be turned off. Reminder tones do not include end-of-cycle
tones. On combination oven models, if “All Tones” have been
turned off, the reminder tones cannot be independently turned
on.
Timer
To Turn Tones Off/On: Touch and hold TIMER SET • START until
a tone sounds. Repeat to turn back on.
Timed Cooking (combination oven models only)
To Turn Tones Off/On: Touch and hold COOK TIME until a tone
sounds and the lower oven display returns to inactive mode
(blank). Repeat to turn back on.
Apr 26, 2010 | KitchenAid Microwave Ovens
F2 Message Code
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 03, 2009 | KitchenAid KHMS155L Microwave Oven
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
Crisp display
yes, it does indicates there is a bigger problem It has run a self- checking program and displayed the error before calling help see in this model page there is a manual of the oven, check last pages if they help u if no still there are instructions what to do and who to connect read it well before calling it will save u more then a couple of $$$ good luck windman
Jan 17, 2006 | KitchenAid KBMC140H Convection Microwave...
Microwave Ovens Logo
94 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
