Yes, I recommend a vehicle specific wiring harness for the installation to be proper. When installing aftermarket stereo units in some vehciles, it is necessary to insure that all of the vehicles components are receiving power during normal operation. FYI, to obtain the proper harness, you will need to provide a bit more information about your vehicle, such as 2 door or 4 door, what version of the Ford stereo is currently installed and whether or not the unit amplified.
Sounds to me like a broken connector on the socket on the motherboard.check, ,or a broken wire at the plug end, check, or the like, or the battery is not making contact as you discovered. Meter the PSU, and wiggle the plug, and socket and see if it makes and breaks connections.
i would like to suggest u about this thingi.
1 reinstall (physically) and than press f2, if its shows than ok
2 i think u have reinstall the unregistered window, that couldn,t install the specific driver for ur fn keys.
3 uninstall ur card from ur laptop and install it in other laptop than see what happened. if its work there than ur card is ok something wrong with ur system.
Did the computer ever work? Have you checked that your memory is properly seated? Remove the bottom plate that reveals the memory modules, pop both loose then back in. Try to restart. Is the battery fully seated?
