Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red Logo
Posted on Nov 10, 2010
No driver for connecting s9 with h Acer 6930G dv home premıum vista 64 bit oktay kartal
Computer freezes / locks up after running a while,
Sounds like it's overheating. Check to make sure your graphics card cooling fan and CPU cooling fan are working. If they are add some case fans. Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it.
2helpful
Cant connect my dcr-hc24e to my windows vista 64 bit. Have my camera set to stream usb but drivers will not work with 64 bit os
upgrade the latest driver compad with vista 64 bit
here is the link to download it
http://www.sony.com.au/section/support?SR=Global%20Choice:Oceania:AU:Regionalsite:get_support
best of luck
2answers
It is taking about 30 minutes, no joke, to print one page. There are long delays and then it seems to do a line and then another delay. This just started today which is a surprise as the printer has been...
Try HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
3helpful
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
Drivers for M5641
There is no difference whatsoever between drivers for Vista Home, Vista Ultimate or, indeed, any version of Vista. They are all the same Operating System just with bits enabled or disabled accordingly.
Please can you clarify exactly which OS you have. Is it 32 bit or 64 bit? You will almost certainly have the 32-bit version and need to go to the appropriate page. 64-bit drivers will not work with 32-bit Os's and vice versa.
Just in case, here is the link for the drivers... yoiu just need to choose the exact OS remembering the 32 bit option (assuming you do have a 32-bit OS)
http://www.acer.co.uk/acer/service.do;jsessionid=D4148C2C74F2951FDADA15EDEA7EC063.public_a_14c?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3734&sp=page15e&ctx2.c2att1=17&miu10ekcond13.attN2B2F2EEF=3734&CountryISOCtxParam=UK&ctx1.att21k=1&CRC=3713735360
3helpful
3answers
Finger Print Reader is not Working on my Acer Aspire 5738 laptop with Windows XP installed on it. kindly
you need to install all the software of this Finger Print Reader and update all the drivers or install the driver.good luck
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
