Question about Xante Ilumina Digital Color Press Printer
Please what can I do to work the machine that says fatal error 133; for xante ilumina
    New Friend:
  • 13 Answers
The 133 fatal error
C head
after turning ON the power or when cover is closed, the sensor detects that the unit is missing.
1. is an Error message displayed? yes
ICheck the OED head unit.
2 is the LED head properly mounted? no
Turn ON power again
3 Does the Error take place again? yes
Replace the LED head Assy.
Posted on Mar 04, 2013
  • Xante Master
  • 7,733 Answers
If you are in a Windows OS it means that:
133 JOIN or SUBST command can not be used for a drive that already contains readers joints.
So uninstall your printer and install it again using the best driver.
Posted on Nov 10, 2010
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Open the top cover. check ubder the LEDs. each one has two sets of cables attached. remove them and put them back again. It should work now.
Posted on Sep 25, 2013
SOURCE:
Xante fatal error 929
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
Feb 11, 2014 | Xante Ilumina Digital Color Press Printer
C9800 fatal error 145
Toner Feed Switch Error. Toner Lock Lever Open Error
145 = Magenta Imaging Drum
Mar 11, 2013 | Xante Ilumina Digital Color Press Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
230:fatal error with Xante Ilumina
RFID Reader Not Installed
Check Connections. Replace the RFID Relay Board Replace the Engine Board.
Jan 09, 2013 | Xante Ilumina Digital Color Press Printer
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
128:error fatal 02
Engine FAN Motor Error
02: Power FAN Error
is the applicable location of the fan connection normal?
If the condition does not change Replace Fan.
Mar 15, 2012 | Xante Ilumina® 502 Laser Printer
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
133 relates to the cyan LED sensor, infact most likey it is the actual Cyan Image drum.
make suer the LED above the Cyan drum is clean, and freely mounted in the spring assembly.
remove and re instal the image drum..
if that does not work, most likely u need a new image drum,Cyan..i bet it is low and due soon for replacement...
good luck
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
Xanté Ilumina: 020 fatal error
unplug power. open rear panel (2 thumb screws) check fitting of the ROM chips, restart..
020 relates to Slot A ROM DIMM
May need new ROM, or that CU PCB if unsuccesful
Jul 21, 2008 | Xante Ilumina Digital Color Press Printer
Xante Ilumina 512 error code
this error can be caused by a new or existing PC on your network. EXAMPLE: the network settings on new DELL pc's are default set to control the network and repair any conflicts..it seems dells dont like Ilumina's, and they get this error code.
Disable the network control function in the DELL settings.
And this error will not re appear until another dell is installed.
Jun 04, 2008 | Xante Ilumina Digital Color Press Printer
445 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
 Mike M
Mike M
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
