SOURCE: Acer Aspire 3000 problem
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Обычная таблица";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
No. JUST
RESET YOUR BIOS SETTING TO DEFAULT. Your HD is OK
SOURCE: Aspire 3000 will not boot
Hello Halfwit, Your laptop is trying to boot from lan because it can't for some reasons to boot normally from the hard-disk. Try to listen if when you power on the laptop the hard-disk spins or makes any noises. If not there could be a problem with the connector that links it to the mainboard. If you hear a noise or the hard-disk spins then you may have a corrupted OS (windows) or some bad sectors problems. The best way to find out would be to try to boot the laptop by using a windows instalation cd. Boot from the cd-rom and check to see if the windows installer find your hard-disk and can copy files to it. You will need to change the boot order from bios to enable the cd-rom to boot first or enter some boot menu (if provided) and select " boot from cd-rom " or such thing. If you need more help with these please post back or contact me or other experts on the live chat function on this site. Good luck.
SOURCE: having trouble with boot up
It was unfortunate that the chat got disconnected deu to some unknown reason. I was able to find some solutions for you, however, to follow all those steps I would need to talk to you continuously. Whenever you see me online, please initiate a chat with me and we will carry on from there. good luck
SOURCE: Dell Poweredge 700 Server problems
Dear jckim, Which server you are using? Usually this error occurs when raid controller card have some problem.Have you getting any error codes?
SOURCE: Valid operating systems fro Power Edge 1800
During the Windows XP setup you will need to provide the RAID driver using a pre-formated floppy disk.
Windows will ask you if you want to provide additional drivers and give you the key combination to use to do that.
Dell PowerEdge 1800 Systems Installation and Troubleshooting Guide
http://support.dell.com/support/edocs/systems/pe1800/en/it/r2053c20.htm
