I have an LG side by side. Every time you open and close the refrigerator the freezer door pops open. The door does not keep sealed shut. How can I fix this?
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
SOURCE: I have a top freezer.
Take a rag and spray windex on it. Wipe down the entire gasket as many times as necessary till it comes up spotless all the way around. Do the same to the mounting surface on the freezer. After this, see if the rear gasket surface at the hinge side looks crushed more than the rest. If so, pop the cap off the top hinge cover and readjust until the gasket looks relaxed.Do the same with the bottom hinge. Remember do these in the order I've given you. Thanks, Dana
the left side of the freezer drawer is not sealing when closed. It is only 4 years old. ice is building up inside the freezer because of this?
This noise occurs after the fridge door is closed if the freezer drawer is also closed. It lasts for a few seconds. Is there a vent between freezer/fridge that opens/closes and this is the vent or motor moving?
