Black & Decker D2030 Iron Logo
Posted on Nov 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Iron not heating - Black & Decker D2030 Iron
Anonymous
Level 3:
  • Black & Decker Master 43,501 Answers
  • Posted on Jan 28, 2011
Anonymous
Level 3:
Answers
43501
Questions
0
Helped
10842797
Points
101584
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Iron not Heating Up or not Working Rightheatman101
My D2030 iron does not heat up the power light and the screen light come on but does not heat up
1...You need to check the iron settings as they have an adjustable knob that controls temperature as well as governs which kind of materials you want to iron. Different clothing materials need different temperature and other settings. Make sure you set the knob carefully. If you are unable to set the knob properly, you can check the user manual and make sure the temperature or heat amount is set at the right point.
2...Another thing that you need to check in order to inspect why the iron press is not heating up is the water reservoir. In some cases, if the water reservoir is empty then the iron press may not be heating up as much as it should.
For this, switch the iron off and make sure it is cool. Switch it on again and top up the water in the reservoir. Now try ironing again to see whether the heat is proper or not.
3....Another thing that you need to check in order to inspect why the iron press is not heating up is the water reservoir. In some cases, if the water reservoir is empty then the iron press may not be heating up as much as it should.
Feb 05, 2024 • Irons
Tefal Ultraglide Anti-Calc Iron
  1. Check the power supply: Make sure that the iron is properly plugged in and that the outlet is working. If the outlet is not working, try plugging the iron into a different outlet.
  2. Check the temperature setting: Make sure that the temperature setting on the iron is set correctly for the type of fabric you are ironing. If the temperature is set too low, the iron may not heat up properly.
  3. Check for mineral buildup: If the iron has not been descaled recently, mineral buildup in the steam chamber could be causing the heating element to malfunction. Try descaling the iron following the manufacturer's instructions.
  4. Check the heating element: If the heating element is damaged or has burned out, the iron will not heat up. In this case, the iron may need to be repaired or replaced.
Feb 09, 2023 • Tefal Irons
Iron not heating
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
2helpful
2answers
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
heatman101
Iron won't heat up.
heatman101
My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Oct 02, 2009 • Irons
Rowenta 6200 iron will not heat
heatman101
My G1490 Shark Iron will not heat up.
your heating coil probally went bad its alot cheaper tp just buy a new iron
Top Black & Decker Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
