I came home and found gibberish on the screen on my Advantium 120. Several clocks around the house were blinking so we had a minor power outage. All the buttons are inoperative.
Unplug it, then when you plug it back in it is on the default screen for set time, turn dial to right for hours will advance up starts at 00, advanced to 01, 02, and same for min. when you are at say 9 press / push in main knob 1x to advance to minutes, and advances to next input so hours, minutes, then am pm pushing button after dialing to am or pm finishes and sets the time. Jeffrey Weber-Reek
If you see no panel on the inside of the unit, you will have to remove the housing.
If it isn't high-mounted, this isn't difficult; there are 3-5 screws around the edge of the back panel that keep the metallic housing in place.
Once these are removed, lift the rear flange of the housing and tilt it forward, then pull it back toward you to release the front lip.
As a precaution; unplug the oven overnight since there are components that can keep a nasty electrical charge for hours, maybe not life-threatening but highly unpleasant.
dis connect from power alow to reset for about a minute . if not there are switches behind the door probably not making good contact make sure door is closed tightly
Super. Threw the circuit breaker for 30 seconds and that restored the Advantium. When you're in New Orleans, I'll buy you a beer.
Larry
