Dishwashers Logo
Posted on Nov 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DISHWASHER DOOR OPENS REAL HEAVY AND FAST - Dishwashers
Anonymous
Level 2:
Champion:
  • Expert 246 Answers
  • Posted on Feb 21, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
246
Questions
Helped
120379
Points
311
I am not sure about the door opening really fast but I do know that if you ever want to change the look of the dishwasher door you should check out www.applianceart.com
they even have stainless steel
John Riley
Level 3:
  • Master 441 Answers
  • Posted on Nov 09, 2010
John Riley
Master
Level 3:
Answers
441
Questions
Helped
138517
Points
1344
It sounds like your door springs are broken, at the top of the dishawasher you will find 2 screws that attatch it to the counter top, take them out and slide the dishwasher a few inches forward, this will allow you to see if your springs are broken. If so you can order new ones at marcone.com w/ your model #
My dishwasher runs but door is in locked position. it will now run with door open and the door wont close/lock
It sounds like your door latch got tripped into the closed position (even though your door is open). You MIGHT be able to use a screwdriver or some tool to be able to pull the latch lever back out to the open position, but it might also be necessary to take the door apart to get to the latch to be able to reset it. The real problem is that if it happened before, it will probably happen again. So the real solution is to replace the latch assembly.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1helpful
What do I adjust to prevent the door from opening too fast? When I open the dishwasher door I must hold it so it does not come down too fast
Herbert,
You probably have a broken door spring or a hing cable. I looked your model up on Sears parts direct and have included a link. You are looking for item #1 or #1A. Good luck! http www searspartsdirect com frigidaire dishwasher parts model...
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
1helpful
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Door springs have come off so door opens and closes very fast and heavy
You will have to pull the dishwasher out to access the springs.
If the end is broken off, simply make a new loop with pliers.
1helpful
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Magic chef dishwasher
As of date I have had no response. Maybe I am looking in the wrong file. I can live with a broken door for now and thanks for you concern.
Aug 04, 2008 • Dishwashers
2answers
Dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
2helpful
3answers
Dishwasher door latch
Its very east to open. Take the top cover plate off the appliance, undoing the screws at tha back and it will reveal the latch.
regards
george
Mar 30, 2008 • Dishwashers
Kitchaide Dishwash Door
There is normally 2 heavy springs & cables that control the "falling" of the door located in the bottom of the machine or it the door itself. Sounds like one (or both) have snapped.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
