Freezers Logo
Posted on Nov 09, 2010
Older model frostless freezer model number 2539280411. The temp alarm light is blinking.
Anonymous
Level 1:
  • Contributor 316 Answers
  • Posted on Nov 09, 2010
Anonymous
Contributor
Level 1:
Answers
316
Questions
0
Helped
105998
Points
21
Is the temperature warmer as well, or is it just the alarm light blinking?
I have a Kenmore Frostless Model #: 253.21041104 The temp. alarm keeps going off. The red light blinks and alarm goes off. Owners manual says that it is from warm conditions, but there are no warm...
Best thing to do first is get a thermometer to be sure the temperature is correct. Items still freeze at higher temperatures. If you have ice cream and it is soft, then you have a temp problem.
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
11helpful
2answers
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Yellow power light keeps blinking on upright freezer even after replacing 9V battery and temperature is good.Have waited about 16 hours for freezer to stabilize. Problem?
If its the power light, and not a temperature alarm light, it may only indicate that there was a power loss, perhaps you had a brown out or power surge. you say the temps are good, any chance you have ice cream or bread in freezer? if its above 10° F they will be first to get soft, rather than firm. If I had the model # as it is on the model number tag, the only tag usually on the inside or possible on the outside, of the unit, that will have the model and serial number both listed.
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
2helpful
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
