Remove the battery cover, press and hold set until it beeps. Use the up down keys on the front and you cycle through year, month/day, then time, then 12/24 hour mode. You advance to each function using the set key. Once through the cycle, the time will stop flashing and the clock will function normally.
Press the 'set' button again after setting the 12/24 hr mode. Flashing will stop and correct time will appear.
