It is possible you have a short. However, the more likely cause is the simple fact the refrigerator is plugged into the GFI outlet. Try this first, take a heavy duty three prong extension cord, NOT a lamp extension cord, plug it into a non GFI outlet, and plug the fridge into the cord. Does it trip your house circuit breaker? If so, then you do have a short. You will need to call a local refrigerator repair company to find the source of the short, and only then will you know if its an easy or cost prohibitive fix. If it does not, and it likely wont, the problem is that a GFI outlet detects a fault to ground. Due to the humidity and moisture inside a refrigerator, and normal water drainage sometimes into the metal base of the refrigerator, it is not uncommon for water to contact metal points inside and outside a refrigerator. Since all / most metal points on a refrigerator are grounded to each other, if water contacts any of them, they can and will trip a GFI outlet breaker, because it is detecting a fault to ground.
