SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
SOURCE: Set the clock to DST
Try this link and follow the instructions.
http://www.lacrossetechnology.com/3143a/manual.pdf
SOURCE: my LaCrosse radio-controlled WT 3144 clock is
I'd say you have a lemon. Manual: http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf For warranty work, technical support, or information contact: La Crosse Technology, Ltd 2809 Losey Blvd. S. La Crosse, WI 54601 Phone: 608.782.1610 Fax: 608.796.1020 e-mail (warranty work) (information on other products) Website
SOURCE: It looses time and the radio controlled feature
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
SOURCE: I need to set my
The nature of this type of clock is that you neither can nor need to set it manually. Your only input is the time zone and it will look for the radio set signal from Colorado. That model does not get any hits on Google. Who makes it?
Manual:
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail
(warranty work)
Website
