Hi Gary The hob connectors have colour coded plug ins. They are starting from right to left the red connector is for the front right plate, the white is for the back right plate, the blue is for the the back left plate and the black is for the front left plate. Now I am not sure of the config in your country but another way to look at this is that The red dot 2000 W (large plate) is connected to the black harness and the red dot 1500 W is connected to the blue harness. The std large plate 1500 W is connected to the white harness and the red harness is for the 1000W small plate. The wiring onto the actual plates should be accrording to the colour codes as follows: The harnesses are all 4 wires and are colour coded blue white ( wiring block 1) , yellow white(block 2), white ( wiring block 3) and the red white block 4. The actual plates are numbered from left to right as 1,2,4,3. But my wiring write up takes it as standard 1 to 4 so do mot worry about the numbers on the plates as some plates have no numbers. Hope this helps.
