2004 GMC Envoy Logo
Posted on Nov 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compass direction wrong - 2004 GMC Envoy
Freddy
Level 3:
President:
  • GMC Master 1,311 Answers
  • Posted on Nov 29, 2010
Freddy
GMC Master
Level 3:
President:
Answers
1311
Questions
0
Helped
647088
Points
2221
Compass Calibration
Before calibrating the compass, drive the vehicle to an area that is magnetically clean or free of large metallic objects. Verify there are no magnetized objects on the inside or outside of the vehicle close to the mirror.
Start the engine.
Press and hold the switch for the compass, which may be depicted as COMP, COMPASS, or On/Off (w/UE1) depending on the type of mirror on the vehicle, until the letter "C" or "CAL" is displayed.
Drive the vehicle in circles at a speed of less than 8 km/h (5 mph) until the "C" or "CAL" is replaced by a proper vehicle heading. The calibration procedure is now complete.
Compass Magnetic Variation Adjustment
Magnetic variation adjustments are required when the compass displays a constant error in heading. Variation is the difference between magnetic north and true north due to geographical location.
Compass not working on 2006 Mercury Grand Marquis
Electronic Compass The compass display and module are contained in the overhead console and are replaced as an assembly. For additional information, refer to Section 501-12 . The compass display can be turned off and on by pressing the MODE button in the overhead console. The vehicle heading is displayed as one of N, NE, E, SE, S, SW, W, or NW.
Inspection and Verification
NOTE: Press the MODE button to turn on the display.
  1. Verify the customer concern by operating the vehicle along roads of known direction to duplicate the customer concern with the compass.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Compass module
  • Central junction box (CJB) fuse 15 (7.5A)
  • Circuitry
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the fault is not visually evident, determine the symptom and GO to Symptom Chart .
Pinpoint Test A: The Compass Is Inaccurate/Inoperative
Normal Operation The compass receives battery voltage from the central junction box (CJB) through circuit 964 (DB/LG). Ground for the compass is supplied through circuit 676 (PK/OG).
    Possible Causes
  • fuse
  • circuit 676 (PK/OG) open
  • circuit 964 (DB/LG) open or short to ground
  • compass zone setting
  • compass calibration
  • compass module
PINPOINT TEST A: THE COMPASS IS INACCURATE/INOPERATIVE NOTE: Always set the zone and calibrate the compass before replacing an inaccurate compass.
NOTE: After installing a new compass, always set the zone and calibrate.
Test Step Result / Action to Take A1 CHECK THE OVERHEAD COMPASS DISPLAY
  • Key in ON position.
  • Check the overhead display.
  • Does the overhead compass display remain on after prove out?
Yes
GO to A3 .
No
GO to A2 . A2 CHECK THE COMPASS MODE
  • Press and release the SELECT switch on the overhead console.
  • Does the overhead compass display turn on?
Yes
If the compass display turns on correctly, GO to A3 . If the compass display turns on, but the heading is inoperative/inaccurate or the display indicates VAR, GO to A4 . If the compass display turns on, but it does not display all directions, or indicates CAL, GO to A5 .
No
GO to A7 . A3 CHECK THE COMPASS DIMMING
  • Turn the headlamp switch to the parking lamps ON position.
  • Does the compass display dim?
Yes
TURN the headlamp switch to the OFF position. GO to A4 .
No
TURN the headlamp switch to the OFF position. GO to A8 . A4 CHECK THE COMPASS ZONE SETTING
  • Set the compass to the correct zone for your location. Refer to Compass Zone Adjustment in this section.
  • Does the zone adjustment set correctly?
Yes
GO to A5 .
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A5 CALIBRATE THE COMPASS
  • Calibrate the compass. Refer to Compass Calibration in this section.
  • Is the compass calibrated correctly?
Yes
GO to A6 .
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A6 CHECK THE COMPASS ACCURACY
  • Position the vehicle at each of the 8 directions (N, NE, E, SE, S, SW, W, NW) and verify that the displayed heading is accurate. The vehicle must be stationary for at least 10 seconds at each direction.
  • Is the compass display accurate in each direction?
Yes
The compass is OK. REVIEW the operation of the compass with the customer.
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A7 CHECK THE VOLTAGE SUPPLY TO THE OVERHEAD CONSOLE
  • Key in OFF position.
  • Disconnect: Overhead Console C930.
  • Measure the voltage between the overhead console C930-1, circuit 964 (DB/LG), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
TURN the key to the OFF position. GO to A9 .
No
VERIFY the CJB fuse 15 (7.5A) is OK. If OK, REPAIR the circuit. TEST the system for normal operation. A8 CHECK THE DIMMING CIRCUIT
  • Measure the voltage between the overhead console C930-4, circuit 484 (OG/BK), harness side and ground while rotating the instrument panel dimmer switch.
  • Does the voltage vary between 0 and 10 volts?
Yes
GO to A9 .
No
REFER to Section 413-00 for further diagnosis of the instrument cluster and panel illumination. A9 CHECK CIRCUIT 676 (PK/OG) FOR OPEN
  • Measure the resistance between the overhead console C930-2, circuit 676 (PK/OG), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
No
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
My compass is going out...what would it cost to fix it?
Sounds expensive to me ,all this fancy electronic stuff ,be cheaper to buy a tom tom
How to reset compass
Select Calibrate compass from the information center, and drive the car in 3 circles. This is best done in an empty parking lot.
1helpful
Sat nav on jag xf. the direction arrow on sat nav always points in compass direction of travel ie if going south then arrow points down over. is it possible to have arrow always pointing up like tom tom
the touch screen on the car should allow you to change the compass setting...I cant remmeber if yours has this but see if you can touch the compass on the screen display to make the direction allow of the car be in accordance with the cars real movement or north as you wish..Keep me posted
The letter C is flasing in my dash board
The flashing "C" in the Instrument cluster if for the Compass. Here's the bulletine...
Subject: Compass Displays a Steady or Flashing "C" In Place Of Directional Heading
Models: 2008 Saturn VUE built on or after 11/09/2007
This PI was superseded to update Recommendation/Instructions. Please discard PIT4699.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern: The compass displays a steady or flashing "C" in place of directional heading.
To return to a normal heading display, press and hold the cluster stem for approximately 2 Seconds.
The displayed heading is not correct after driving for 30 seconds, use the following "Compass Calibration" routine.
Press cluster stem until the Season Odometer is displayed (Not Trip A or B).
Press and hold cluster Stem until the solid "C" is displayed. To the right of the "C" will be the "Zone". Refer to the variation zone map above for the correct setting. Turn the stem Right to increase, Left to decrease. It will take a few seconds for a change of zone to be updated in the display.
Once the Zone is correct, press the Stem to display the Flashing "C". Do not touch the Stem again until the direction is learned. Drive the vehicle in slow circles in an open area until you see a compass (oc tant) heading replace the flashing C.
Note: Vehicles built prior to 11/09/2007 were not built with a compass.
Recommendation/Instructions:
Engineering is aware of this condition and is in the process of root causing. It is known that the Remote Compass Module (RCM), Body Control Module (BCM) and Cluster hardware are not at fault, and these parts should not be replaced.
Reinforce with the PDI technicians that the Compass Zone and calibration is still required as part of PDI.
Hope helps (remember to rate and comment this answer).
Built in electronic compass on 2004 GMC Envoy is giving the wrong directions
Try the following;
Compass Calibration
Start the engine.
1helpful
The compass on my 2002 Subaru Outback is about 180 degrees wrong--It just started.
check for any sources of magnetism near the compass, speakers, phones, mobile phone accessories etc, there could be something in the glove box, empty the car of anything likely to have a magnet in it and check the compass again.
1helpful
I have 2002 Yukpn Denali XL. There is a OC code that appears in the rear view. What is the cause of this and how can I fix it?
The "OC" indicates your compass is "Out of Calibration". Below is the proceedure to recalibrate your compass.
Compass Calibration
The compass may need calibration if:
 After five seconds, the display does not show a
compass heading (N for North, for example), there
may be a strong magnetic field interfering with the
compass. Such interference may be caused by a
magnetic antenna mount, magnetic note pad holder
or a similar magnetic item.
 The compass does not display the correct heading
and the compass zone variance is set correctly.
In order to calibrate, the letters CAL must be displayed
in the mirror compass windows. If CAL is not
displayed, push in the COMP button for approximately
eight seconds or until the letters CAL are displayed.
The compass can be calibrated in one of two ways:
 Drive the vehicle in circles at 5 mph (8 km/h) or less
until the display reads a direction, or
 drive the vehicle on your everyday routine and after
several turns the compass will become calibrated and
will display a direction.
Good luck.
1997 Nissan Terrano electronic compass blinking
CORRECTION FUNCTIONS OF COMPASS
NAEL0307S01
The direction display is equipped with automatic correction function.
If the direction is not shown correctly, carry out initial correction.
INITIAL CORRECTION PROCEDURE FOR COMPASS
NAEL0307S02
1. Pushing the “Mode” switch for about 10 seconds will enter the
initial correction mode. The direction bar starts blinking.
2. Turn the vehicle slowly in an open, safe place. The initial correction
is completed in one or two turns.
NOTE:
In places where the terrestrial magnetism is extremely disturbed,
the initial correction may start automatically
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
