You will need to disassemble youre laptop and get to the cmos battery. This is located in the bottom right hand corner of the inside of the laptop and looks similar to a watch battery. Do not have your laptop plugged in being charged and have the power shut off. Take out the battery and disassemble the laptop. Leave the battery out for about 30 minutes to reset all bios settings, including your password. This should work and you will then be able to enter into Windows.
you'll need to leave it out for about 30 min...
OR TRY THE FOLLOWNG
Please i need the rescue password to asus notebook pc x553M FOR BIOS date 2014/08/09
You can erase the BIOS password by just removing the primary battery as well as the CMOS battery. The logic is, if there is power to the CMOS chip, then it can't remember the settings.
Did you remove the CMOS battery as well? Its a small CR2032 battery.
Looks like a disk.
Usually, not more than a minute. It looks like we have too look at other options. I forgot to ask you a question. By BIOS password, do you mean the password required to enter setup or a system password?
SOURCE: remove password from award bios on asus laptop
SOURCE: Bios password
Ah that difficult with a laptop.
use this tool
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
or flash the bios from the laptop manufactor sites bios update.
or failing that - open the laptop up. take out the on board battery or search on line for where the jumpers are situated on the motherboard and reset them.
No easy solution im afraid.
JPW
SOURCE: I forgote bios password, IN MY ASUS EEE PC4G
I'm doing this from memory because I don't have an Asus handy. Reboot the machine press F11 to get into BIOS before the password screen comes up. You may have to try this several times. I've never tried this but I read on the Asus site that if you press CRTL-ALT Del while the unit is booting, that will put it into Administrator mode. Leave the password it asks for blank.
Good Luck
SOURCE: forgot asus laptop password Windows vista
To reset your ASUS laptop Windows login password, I think you can try this password recovery software, fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. You can do it on your own, no need to send it to a computer shop. Regards.
how long should i leave both batteries off? because i'm still getting prompt for a password
yes both batteries. and still the same thing.
how long should i leave it off?
yes, its the one as soon as i boot the machine up it ask for the password in order for it to boot into windows.
i did it for 20 min but its still giving me the error
im needing help resetting, or clearing the BIOS password. Meaning when booting the machine it prompts me to put in a password before the windows logo even comes up. i had it set before and forgot my own password.
ok its been out and upluged for about 15 min now. i will waiting another 20 to be safe and give it a try.. stanby so i can get you paid if this works.. thanks a million for your time.
ok that didn't work. it still prompts me for the password. after leaving the cmos out for 45 min. any other suggestions?
nope didn't work. left it out for 45 min.
sorry "NONE" of the passwords worked total of 24 passwords
