Windows 7 32bit or 64???????????????????????????????
DM , right click update driver. on the driver bad. in DM.
be online or it's hopeless.! (this is called asking MS for the driver)
using PnP, w7
where are you inserting this card
sandisk micro sd card
directly in to the PC
or via a store bought USB ADAPTER.????\
my guess the JMB38X
my hp LT has a slot built in but needs the HP driver to work
from HP. we here are not HP, at all,
ill pretend you said w7-32bit and answer.
here are all drivers need , for Day 1 usage on the new PC
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv7-1200-entertainment-notebook-pc-series/3837623/model/3860629
the built in reader only suports these cards stated in your manual below
http://h10032.www1.hp.com/ctg/Manual/c01485097
Memory Stick (MS)
Memory Stick Pro (MSP)
MultiMediaCard (MMC)
Secure Digital (SD) Memory Card
xD-Picture Card (XD)
xD-Picture Card (XD) Type H
xD-Picture Card (XD) Type M
my guess is one of these driver match
on the HP forum the guy said
The device 'JMB38X SD/MMC Host Controller' (PCI\VEN_197B&DEV_2382&SUBSYS_30FC103C&REV_00\4&3b4983b4&0&0028) disappeared from the system without first being prepared for removal.
i dont see the driver there, at HP.
(might be bundled with others there, as is HP practice some times)
why not run the HP assistant
and end this. seen THERE
here there are digging up; old vista driver for same.
https://h30434.www3.hp.com/t5/Notebooks-Archive-Read-Only/DV7-1245DX-Notebook-JMB38X-SD-MMC-Host-Controller-Error/m-p/30988/highlight/true#M33929
goal.... how to get it and not get a virus doing so. as always. endless works. that.
JMicron JMB38X Card Reader Driver
most Jmicron links are dead, (after 7 years easy)_
why not ask here, on topic HP REAL
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=+JMicron+JMB38X+Card+Reader+Driver
they built it, so maybe they have drivers,
they do 10 years or newer. PCs HP.
Go to control panel -> system and security -> system -> device manager. that has a list of all the hardware on the computer, look for any items that have X ! or ? next to them. Could be that you don't have a driver loaded for that device.
SOURCE: SD Card Reader won't work?
have you tried other sd cards before or is this the first time?
if you have and its just this time it hasent make sure its working in your camera or mp3 player or where ever it came from :-)
if it works have a look in your device manager to make sure there are no problems with the drivers.
1 start
2 control pannel
3 system
4 then the hardware tab and click the device manager.
if there are anyproblems there is useually a little symbol next to the device just double click on it and have a look for the error code.
if all else fails try reinstaling the driver for your card reader or find an updated drivr download.
hope this helps
SOURCE: Recognizing / Reading SD Card?
Yes...go to the google website or drivers.com to find the driver of your computer and you can type the search box "dowload" your specific brand of you pc..............
SOURCE: SD card reader
1) There is SD card reader on pavilion dv 1000, so you need adapter in which you insert mini SD card to make it SD
2) If you have that adapter, check adapter. Maybe it's broken.
3) If your card is biger, like 2GB or higher you may try updatenig drivers (I read on one web page: "
There was a software update for support of reading and using higher memory SD cards, for my pavilion ZV5000, on the HP Software update website." )
SOURCE: SD READER
Check if the device is working
Check if you see the device in your computer ("removable disk")
Try using another SD Card
If not working
Try reinstalling the driver and software to your SD reader.
Uninstall first before reinstall it.
You can get the driver and software at your laptop manufacturer website
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
Have a great day!
Pablo :-)
SOURCE: HP Pavilion ZD8000 Digital Media Reader Issue
Try updating you drivers for your digital media reader. Also check your dcos to see if the DMR will read a 2GB card
What happens when you tried to plug-in SD card to the computer?
Have you made any recent changes to the computer prior to the issue?
To make the SDHC be recognized by the computer, we need to ensure that the card reader works in Windows 7 first. Please check if the card reader is recognized properly by the computer and you have installed the driver for it.
Meanwhile, you can plug some other storage cards to the card reader and see how it works.
I would suggest you to refer the link below
A Secure Digital (SD) card may not be recognized on a Windows 7 based computer.
http://support.microsoft.com/kb/981642
Uninstall all the Generic USB drivers and reinstall.
1. Open Device Manager.
2. In "Disk Drives" dropdown, uninstall the "Generic SD/MMC USB device" drive.
3. Restart computer.
4. Insert SDHC card.
Hope this helps.
Hope this helps.
