You can download a manual or quick set-up guide from the D-Link web site support section.
You can connect to the router using a LAN cable or to wireless dlink and use the IP address of 192.168.0.1 should allow you into the set-up menu. The default router login is ADMIN and password is blank. You should be able to set-up the router without a CD.
SOURCE: D-link cd-rom
connect the router by cable, less chance of data loss
http://192.168.0.1
will open the routers web interface, all settings can be made from there without the cdrom
SOURCE: i need to download the installation cd
You do not need to install any software in order for a router to opperate.
SOURCE: I need the cd-rom for wireless router d-link DI-624
hi there! this product is already End of Life product. I check with the website for dlink and there is no available cd for this product. but if u want to setup your router, you can use the router setup page by typing at the url of your browser, 192.168.0.1 and it will ask the username and password, by default the username is admin and the password, just leave it blank, then it will show the setup page of the router, no need a cd to setup ur router.. i hope this info will help u..
SOURCE: Lost Installation CD Rom for D-Link DIR-615
Try going to the d-link.com web site, and see if you can download it from there.
Testimonial: "Thank you for all your help, HAPPY NEW YEAR!"
SOURCE: Lost Installation disc for D-Link WBR2310 wireless
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
