How do I get a copy of the settings on my Speedstream 5100? They say go to http://speedstream or 192.168.0.1, but the pages are not found. I can't find any upnp device they talk about. I have windows 7.
Re: How do I get a copy of the settings on my Speedstream...
Try to check the Default Gateway of a computer that is directly connected to your router. Type the default gateway your browser. Here is how to check it Checking IP and Default Gateway on Windows 7.
in your browser type 192.16.0.1 and it will take you to the modem admin page.
Press the check connection button and it will tell you how your connections are doing. If it shows DSL/Internet down, then most likely your ISP is down 95% likely), or your modem is bad (happens pretty often with these things)
If it doesn't take you to the page, try using 10.0.0.1 some of the newer 5100s have that as their address. Same options and advice.
Option 1 (easy) you could buy a switch or router and put in line with your modem. you will have to set up appropriate networking on the xbox DSL --> MODEM --> SWITCH <-- PC ^---- XBOX
Option 2 (harder) you could get a wired/wireless AP (Access Point) for your PC and run ICS (Internet Connection Sharing) through Windows. connect the XBOX through your PC
The underlying Ethernet connectivity required for the broaband connection was not found. Please install and enable the Ethernet adapter on your computer via the Network Connections folder before attempting this connection.
If u don know to install the ethernet adapter pls do contact your vendor
