right to resync the remotes you need to open the little door at the front of the wii console then there should be a red button behind it then open the wii remote where the batteries are then theres a little sync button and hold in both buttons then the remote and console should link up
with the dualshock controller scroll over to settings. go down and select acessory settings. then go to bd remote. follow the prompts from there, simple. please rate
Registering a BD remote control 1. Prepare the BD remote control. 2. Select (Accessory Settings) under (Settings) in the home menu. 3. Select [Register Bluetooth® Device]. 4. Select [Register BD Remote Control]. Only
one BD remote control can be registered at any given time. If you
register another BD remote control, information on the currently
registered headset will be overwritten. 5. Follow the on-screen instructions to register the BD remote control. When the registration (pairing) is complete, a controller number is assigned. Hints
When seven SIXAXIS™ wireless controllers are in use, you cannot register or use a BD remote control.
If
you register the BD remote control with another PS3™ system, the device
registration with the first PS3™ system will be cleared.
For detailed usage instructions for the BD remote control, refer to the instruction manual for the BD remote control.
you must connect the controller to your PS3 with a USB Cable, this will sync the controller with your console and you will be able to use it wirelessly after this. good luck!
ps3 console on television when plugged in it says no device found
