Question about Panasonic NNH965BF Microwave Oven
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
  • 8,197 Answers
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Posted on Nov 08, 2010
SOURCE:
Ge microwave m# pvm2070sm1ss. Control panel nonresponsive, attempting to check if creen lock is engaged but cant get past "change the filter"message.
I have never seen a home microwave that shuts down the unit to have you clean the air filter. Mostly they are reminders that stay up for a preprogrammed time. Have you tried to unplug the unit,let it set for a couple of minutes, Plug back in, set the time of day (clock ) and try it again?? If you get NO action from the touch panel, the touch panel may be bad.
Aug 24, 2017 | GE Microwave Ovens
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
I have a Kenmore microwave with an error code SE or 5E model No: 401.80082700
The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
Not really a DIY job. Microwaves can retain up to 2200V even when unplugged.
control panel frame assembly ("control") , which comes with a new keypad already installed lists for $59.99 fyi.
Feb 22, 2018 | Microwave Ovens
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
The message "demo mode" is
you should go to main switch and there should be a button make it open thats a solution..........................
Jun 02, 2011 | Microwave Ovens
Error message E8 is shown in the clock display
Error Code: E8 Cause: Control Board Example: Remains in display; oven unusable Corrective Action: Replace control board
Apr 12, 2010 | Bosch HMT8625GB Microwave Oven
How to set the clock on my sharp carousel microwave
Touch STOP/CLEAR pad.
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
Sep 25, 2009 | Sharp Microwave Ovens
Cannot control Microwave, no action when clearing, setting, etc
This sounds like a door switch or key pad problem. If you haven't already tried this..... unplug the unit from the wall for atleast 1 hour and plug it back in. See if this helps.
Sep 11, 2009 | Microwave Ovens
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag microwwave oven
check the magnitron and capacitors one of this bad
Sep 18, 2007 | Kenmore 80412 Microwave Oven
Panasonic NNH965BF Microwave Oven Logo
1,449 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
