SOURCE: nedd help setting time on columbia watch
Ple disregard all prior instructions. They are either wrong or a step was forgotten. Press "set" for 5 seconds. Then "mode" until you see 12-Hr flashing in the window, then press "ST/SP" until you see 12-Hr flashing, then press "mode" again until you see the word "hour", and the actual hour is flashing. At this point, you may increase time by pressing the ST/SP button or decrease by pressing the "Reset" button, then the "set" button. Enjoy!
SOURCE: columbia watch - set time
Hope this helps!
I found it finally!!!
Good luck, I hope this helps you!!!
Columbia by Fossil Customer Service Contact
Contact this seller Phone: 800-449-3056
SOURCE: trying to set time on my columbia CL5046
When The Watch Is In Normal Time Mode, Press The "SET" Button. Then Keep Pressing The "ST/SP" Button Until The Time Is What You Want. Then Press The "MODE" Button To Move On To The Next Field. When You Are Completely Done, Just Press The "SET" Button Again. Hope This Helped
SOURCE: Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
