SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
SOURCE: oe code on LG dishwasher following garbage disposal replacement
Well, there is the plastic block in the garbage disposal where the drain hose goes on (as not every disposal will be attached to a dishwasher). Punch this out with a screwdriver, fish the plastic plug out with your hand and reattach the hose. You are good to go.
SOURCE: dishwasher finished cycle, but still full of water
take some drainig liquid and let it sit in there over nite if that does not work take out the drain and take out the old grub manualy (i think what u want to put in the dishwasher is vinagear or draino something
SOURCE: I have water leaking from bottom of dishwasher
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your
dishwasher, you may be using a detergent that is causing too much suds. Cut
back on the amount of detergent you use, and see if that makes a difference.
Water
that spills through the door vent is usually caused by improperly loading
dishes. Leaks from the door itself may be caused by a faulty door gasket or
door tightness adjustment. You should check the main tub seal, the door latch,
the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet
up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose
connection. Remove the lower front panel, and check the hoses. The pump seal
may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If
this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
SOURCE: GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Hi, 1
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
