Question about Ranger Communications RCI-6900F-25 CB Radio
How do you change the antifreeze on a 2001 ranger 4.0liter step by step
    Genius:
  • Ranger Master
  • 1,847 Answers
Look under the radiator and you should see a petcot valve, wing nut . turn it till you see your old antifreeze coming out then once it stops tighten the nut and fill the radiator .
Posted on Feb 23, 2015
SOURCE:
2001 Kawasaki VN 1500 Vulcan Nomad how to change the coolant
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Step by step coolant flush and change Kawasaki Vulcan Forum Vulcan Forums
How to replace motorcycle coolant
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
2001 Kawasaki Vulcan 1500 Nomad Fi Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 10, 2014 | 2001 kawasaki VN 1500 Vulcan Drifter
I have a 2001 ford ranger and white smoke is coming from my tailpipe that smells like gas
your tail pipe is always going to smell like gas the white smoke is oil being burned from worn out valve guides or rings.
Dec 09, 2010 | Ford Ranger Cars & Trucks
Heat in my 98 ford ranger not working it blow out cold air from defrost only
check antifreeze level make sure its full with antifreeze and not just water if full check heater core for leaks see if it is antifreeze on the passenger side floor
Feb 05, 2010 | 1998 Ford Ranger SuperCab
2001 Ford Ranger will not start easily, runs rough when does...Thought I had water in gas/fuel line freeze up...added fuel antifreeze. Got it to finally start had to use jumper cables. Drove truck would...
tune it up,plugs,wires,rotor and dist.cap if equipped,clean butterfly in throttle body,has carbon build up.use tooth brush and throttle body spray cleaner.when starting,never touch the accelerator,this will make it go in the limp mode or throw a code
Jan 31, 2010 | 2001 Ford Ranger Regular Cab
I have a 2001 ranger 4.0 automatic w/od and 40k cruise control
Ford has a recall on yours if a tilt wheel is an option in your truck
Jan 16, 2010 | 2001 Ford Ranger Regular Cab
2001 Ford Ranger using antifreeze
you have to pressurize the cooling system. once you have pressure in system if it holds you can remove spark plugs until you see it effect the pressure gauge then you will know for sure if its going into cylinders and being burned as you drive. other way that sometimes works is to remove radiator cap and look for bubbles coming up,giving indication of compression in coolant. all tool trucks sell a head gasket testing kit that reads the gas in your radiator but it cost about 70 dollars . that is the most accurate way besides constant white smoke out of your tail pipe .
Jan 11, 2010 | 2001 Ford Ranger Regular Cab
How to replace the fuel filter on 2001 ranger
A Chilton or Haynes manual from the library would help you find, and replace any part on your truck including what tools you'll need. They're also available at most auto parts stores or they can special order them for your truck. They're a HUGE help in any repair you do to your vehicle showing you step-by-step how to do it.
Mar 01, 2009 | 2001 Ford Ranger Regular Cab
Ranger Communications RCI-6900F-25 CB Radio Logo
101 people viewed this question
Top Ranger Radio Communications Experts
Steve Allison
Steve Allison
Mike Charette
normis101
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
