Take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
No truth to powder being better .fabric softeners on the towels is fine it does help keep them soft they just don't absorb moisture as well.. I belive you biggest issue is over drying the towels,use a lower temp setting on dryer and do Not trust auto dry settings for towels,expermint with timed settings, if towels are not dry you can always add a few more minutes,but over temp and over dry will stiffen and age them prematurely
If the model number you have this question listed under is correct, the Duet dispenser tray is arranged as follows:
1. The LEFT compartment is for detergent. There is a separator guide that needs to stay in place. Place it in the forward most position if using liquid detergent and the aftermost position if using powder.
2. The RIGHT FRONT compartment is where you put liquid fabric softener.
3. The RIGHT REAR compartment is where you add liquid bleach.
An illustration with full explanation is available on Page 12 of the Whirlpool Duet owner's manual. If you no longer have a manual, you can go to managemylife.com and download or print a copy for FREE.
If you have any further questions, or if your model number is different, please post back and let me know. I hope you find this information helpful.
Hi.
No prob, but it would be adviseable to use a product called CALGON, it is a water softning powder, and will prevent build up of lime scale in washer due to hard water.
Please rate my solution.
Thanks.
If your clothes smell worse after washing then the machine is full of gunge from all the previous washes. One of the worst things that puts a gluggy deposit inside machines is of all things Softener! You could try putting a generous two cups of Sugar Soap Concentrate into your machine and filling it with warm water. Then let it stand for 24 hrs, Then start the wash cycle. This may clear the gunge. If not the only sure remedy is a strip down and degunk and that will cost you a few dollars.
this may be due to a faulty solenoid, if the cold water is flowing into the machine under normal use at the start, then check the solenoids as the conditioner has its own,
the solenoids are just behind the body where the water pipes fit to the machine, they have 2 wires on each one, and are tested for circuit when machine is unplugged.
stat there, hope i have helped
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
its not the sediment that is the problem the filter will do nothing for this problem.The best thing to do is to remove the drawer from the machine and clean the syphon on the softener compartment.It becomes blocked when excessive amounts of wash powder is being used.Alternatively the powder can be put straight into the drum.
