SOURCE: Instructions for ladies' Armitron 45/6974
From the instructions that came with the watch:
Press the button at the top left to get into time change mode, press on the bottom left button to move between seconds, hours, minutes, etc.
Press the top right button to change numbers; hold to move quickly.
SOURCE: Ladies Armitron 45/6967
I used the instructions on the Armitron sight (www.armitron.com) for the model 45/6963 (page 2 of ladies digital). Follow their instructions but NOT their picture of the watch buttons. For the model 45/6967 the buttons are as follows:
A = lower right
B = lower left (this one is the same as on the picture)
C = upper left
D = upper right
I drew a circle and labeled the buttons according to the list above, then followed their instructions (pushing the "A" button when instructed to do so, but my "A" button is the lower right button, NOT the upper left as it appears in their picture) I was able to do all the setting/adjusting of my watch.
Hope this helps. Merry Christmas.
SOURCE: How to set armitron digital watch 45/6915?
Assume A B
C D
To turn off the alarm press & hold A then press B, do this several times until your alarm/chime is either on or off.
SOURCE: How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given
their positions relative to where numbers would be on the face of an
analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The
options appear in this order each time you press the "ST/STP" button:
minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
