Parrot Hands-Free Car Kit with LCD Display for Bluetooth-Enabled Cell Phones Logo
Posted on Jun 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Parrot 3100 LCD Phone book problem
Hi, help please. I've just bought an LG U990 Mobile and tried to pair it to my Parrot CK3100 LCD, it has paired but the phone book won't show up on the Parrot screen which means I can't use set the voice recognition up, any ideas?
Daniel Boyes
Level 2:
Sergeant:
  • Parrot Expert 436 Answers
  • Posted on Sep 23, 2009
Daniel Boyes
Parrot Expert
Level 2:
Sergeant:
Answers
436
Questions
0
Helped
197846
Points
895
Go into phone book, select mark all then send as a business card to parrot.
My blackberry bold 9780 won't automatically connect to my parrot CK3100
when pairing your blackberry, the phone asked to accept connection, just below this there is a small box saying (dont ask again) you must tick this for auto connection. hope this helps
1helpful
4answers
I've bought a used car with fitted Parrot CK3100. When trying to pair with my Nokia 6230i, I manage to locate the Parrot. When I press the 'Pair' command, I'm told to enter the code, but before I can even...
before jumping into updating or flashing the software of the unit we may try few steps to get it working.
try this one:
on the parrot go to settings
advanced settings
pair with phone....
(on your phone...search the parrot.)
set the pairing using the "1234" password.
if that doesn''t work
try to push the red the green and the wheel.(this method will reset the CK1300) whne pushing do not let go until the screen changes display, may take at least 3-5 seconds.
after this try the pairing once again.
hope this helps, good luck
Aug 02, 2008 • Cell Phones
Will not connect to phone
Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
1helpful
Hi, I seem to have lost the bluetooth connection on my parrot CK3100, it was working fine, when I switch on my car it comes on but there is no connection at all, how can I fix this?
First, you will have to come back into the vehicle and switch on to get the kit under power supply.
With your mobile, just switch off and retreive the battery of the phone during a minute and put it on again. You will see something happening a research of the phone to pair automatically.
If not, you can try to go to settings- > paired device and then select your phone broadcasted and connect. You will see an answer and get an idea.
But you can also rebuild the pairing between both devices, then delete the phone paired and use a specific menu into settings -> advanced settings -> pair with phone and select one of them.
1helpful
Just bought a car which has Parrot CK3100 in but cannot pair it up with my nokia 6600, any suggestions. My phone asks for password???
passcode is 1234 but you will need to go to settings / paired device / select any phones that are there and delete them first to make room for new devices.
Cannot pair up n95 with parrot ck3100
you willhave to send the contact manually to the parrot you can try making all but if this dont work you will have to send them one by one.
6helpful
4answers
Unable to pair with CK3100
You need to reset the Parrot first.
Hold down red and green buttons together until she tells you that the memory is being cleared. Then she will prompt you to pair your phone.
9helpful
6answers
Pass code parrot ck3100
what is the code for my parrott ck3100 for my sprint phone
2answers
Pairing LG Shine phone with Parrot ck3100
Call Safewireless.com, they helped with my problem even though I didn't buy my Parrot from them.
Good company that knows their product!
2answers
I can't connect Verizon Gleam SCH-U700 to Parrot CK3100
This solution came from Parrot Tech Support and it worked for me:
We were able to get the two to pair using the following steps:
The phone will stay saying pairing, then the parrot will say pairing successful, pull the battery on the phone, when you turn it back on, the phone will display PARROT CK3100 WANTS TO PAIR, ACCEPT? Say YES.
Mar 11, 2008 • Cell Phones
Top Parrot Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Parrot Car Audio and Video Expert? Answer questions, earn points and help others
