The problem is intermittent but now is happening more often than not. the unit will power up and there in the click of the unit turning on, then a second click ( i think the amp ) and then nothing. both these sound have always happenned, but now no sound. it is across the board with any imput. if i turn the unit off and on a few times i can get it to work once in a while.
There should be 3 clicking sounds coming from the amp. You amp miss the last clicking sound coming from the speakers ,spk, output terminals. There should be 3 relays on the spk output board. Their 12 contact points may have a layer of black colour oxide. Remove the oxide can fix the problem, perhaps.
1. Unplug the amp.
2. Open the cover
3. At the spk terminal, there is a horizontal board.
4. Look for the 3 relays and take them out.
5. Open the relays and remove the oxide layer by a sandpaper.
6. You need an iron solder, a desoldering pump and solder.
7. If does not help, check for the 24V for the 5 relays. 2 is for B+ and B-.
SOURCE: Onkyo receiver problems
All speakers and lines OK? Sorry for basic approach!! Protection is supposed to work when speaker outputs are loaded under recommended Z. speaker Z is a setting too ... along with several other paramenters. Also, re the "last return" ... Maybe the back surround speakers were turned off in settings? Again, apologies if you've tried all this basic stuff. I've just bought one of these amps and have probs with the FM tuner not tuning anything. Mmmm. Back to the shop?? Cheers, Chris
SOURCE: Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
SOURCE: Onkyo 805 : Display not on, but everything else works.
Finally one of us found the solution - thanks to cambrian
Please follow the link
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
SOURCE: Can't find code for Motorola Starchoice sat.receiver
Hello, I just tried the same thing for about 2 hours on a buddies system. I did find on the internet to try 0000, 0001, 0002, 0003, 0004, to 0007 see if one of these work?
Same problem, but only the front right channel is not working. If i power the unit off and on a few times it will work. Or if i turn the volume up it will start to work.
Quite often, when i switch on the receiver, i hear the 2 clicks but then it doesn't output any sound. Clicking off / on random number of times solves the problem - don't know whether this is coincidence or not but it does happen when the weather outside is rainy / gloomy :-)
The reciver function fine but there is no sound coming out.
