There are different reasons why this might happen. Let's try some. 1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!) if not then 2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try Well if that doesn't work, tell me more! Regards, Armando
SOURCE: OUT OF RANGE on monitor screen
you have to change frequency of monitor to work smoothly form display property.
Out of Range is frequency is not matching
To solve this, wwhile booting Press F8 to get advanced boot menu from that select "Enable VGA mode"
change the display properties
right click on desktop - Select properties - Settings - Advanced (from bottom) - goto monitor tab - change the frequecny to default. and restart the system normal mode
SOURCE: Blank screen using Vista x64 with Nvidia Forceware Drivers 8600GT
Most like the sound card you have is not compatible with Windows Vista. You need to check the manufacturers website to see if there is any patch for Windows Vista
SOURCE: video card not working with xp sp3
The drivers for XP and Vista are different. You will need to install the drivers for XP as well as Vista for dual boot operations. Make sure you install the XP driver in the XP partition and the Vista Driver in the Vista partition. This should solve the problem.
