I have a slim DLP TV, standby light, timer light, and lamp light turn on and continue to blink but tv won't turn on.
When turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
I too have this problem, but mine still has the original bulb (about 1 year old). Grey, transparent bar extends vertically down extreme left side of screen, and is about 2 inches wide. Only visible when TV is in 16:9 mode with HD channels.
