Question about Canon ZR80 Mini DV Digital Camcorder
Battery pack use
My camcorder works with power but when i install battery pack it doesnt work,
  • barger_bunch Jun 15, 2008
    its not the batteries i have 3 sets 2 new 1s and orginal 1 ,ive had them checked they work in my friends camcorder ,but not mine i dont have a battery in the memory could that be it
  • Canon Master
  • 2,794 Answers
Have you charged your battery?
Your battery may need to be replaced. Radio Shack carries them for about $20 - $30 a piece depending on how long the life is in them.
I carry a few for my camcorder just for that reason. Then you will have a backup source.
Posted on Jun 15, 2008
  • Tim Babcock
    Tim Babcock Jun 15, 2008
    The battery in the memory only keep track of the date and time as well as the camcorder settings.
    It has to be the battery contacts if the batteries are fine. You might want to inspect them for buildup.
    You could check the back of the batteries too and see if theres carbon buildup or oxidation causing contact with the camcorder to occur. You have to be careful when you clean them as to get one contact at the time or you will cook the battery.
    If you have a test meter and the camera is plugged into the electrical outlet you could test the battery contact points to see if you are getting power to them.
  • Alec Milsky Sep 25, 2013
    I have an identical problem. I purchased new batteries, checked voltage on camera contacts- still the camera wouldn't work on battery. BTW, what are two terminals identified as B and D on the battery? Thanks
SOURCE:
How do i get the casette out of the canon mv700i ? i see a push button on the casette but it doesnt work.
You may need to have a charged battery pack attached to the camcorder (or use the mains power lead, if applicable), so that the camcorder has power to open the cassette door. You may even need to turn the camcorder on. These are safety refinements so that the eject button does not accidentally open the door, leading to possible loss of cassette or damage to the camcorder itself.
Jan 27, 2016 | Canon MV700i Mini DV Digital Camcorder
Sony Touch Screen in camcorder hc26 do not work. thanks
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 28, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Hi having problem setting date ,month ,time on camcorder . The touchscreen is not working when i press against screen
Note: Please make sure that the Camcorder is turned ON while pressing the reset button.
Feb 22, 2011 | Sony Handycam DCR-HC20 Mini DV Digital...
TOUCH SCREEN DOESN'T WORK TO PLAY VIDEO
Jan 27, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
MY SONY CAMCORDER DCR-HC20 TOUCH SCREEN IS NOT WORKING
Jan 15, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
When I turn on my handycam sony DCR-HC 35,the touch-screen don't work!? What can I do about it?
Jan 05, 2011 | Sony DCR-HC35E Mini DV Digital Camcorder
I went to charge my canon FS100 camcorder than went to turn it on and it not working now what can be the problem?
have the same prob this morning, check the charging unit for the serial no. (will begin with CA) mine is CA590E, the 590 is a known problem to cannon, it will either discharge the battery pack (pray this is the fault) or it will internally damage the camcorder. mine is only 18 months old used a max of maybe 10 times. I will reply again this afternoon when i've tried a new battery charger, just waiting for my cannon dealer to open.
Mar 01, 2010 | Canon FS100 Flash Media Camcorder
Battery pack use
I have a similar problem. My MV650i works from the mains power but not from the battery even though I have tried new battery packs.
Feb 01, 2009 | Canon MV650i Mini DV Digital Camcorder
Power problem
Hi, replace the battery pack
Jan 24, 2008 | Sony DCR-DVD301 DVD Camcorder
Canon ZR80 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
