I would assume you are talking about the thermostat switch. These switches are very simple to repair on your own. They are open without any housings and can be accesses by generally removing the panel from the heater. These thermostats fail at the two contact points due to the consistent arcing from opening and closing or on and off. These arcs create carbon buildup which then will not allow them to make the continuity necessary to turn the heater on. In some cases they may even fuse together keeping the heat source consistently running. If the heat source is continuously running with a faulty thermostat the thermal fuse may fault out. If the thermal fuse faults the fan may work but the heat source will not. These fuses will need replaced by an experienced person, you can generally pick these up on ebay for a few dollars. For carbon build up use a small wire brush to remove, while using fine sandpaper to drag between the contact points of the thermostat. Good luck. Mike
These unfortunately are disposable heaters and a replacement thermostat costs more than the heater. You can purchase the heaters all day long for twenty dollars at many of the major hardware stores. Trust me as long as it works and you are there to unplug it use it till it dies, never let it on when you are not around. These are called milk house heaters at Home Depot. I go thru at least two to three of these a winter in my facility.
sounds like your fan is not turning you may need to unplug and try to move the fan motor by hand this may take a few tools to open the unit and see if its stuck if it is try sprayin the motor shaft with wd if ti turns by hand
The heater "over-heated". It's supposed to have a safety cut-out. The question is, can it reset itself? If there is no manual reset button on it, leave it unplugged for 30 minutes or so. If it still doesn't work, spend $20 on a new one.
Hi Spybotics. I have the same problem and I traced mine down to a burned out over-heat fuse link. Check out my recent post. My guess is that you are having the same problem as me. It's not hard to tell - just take off the rear panel and test the link (looks like a small resistor in line with the element) with an ohm meter. Open circuit means burned out fuse link. DO NOT bypass the link, as an extreme fire hazard will exist without it.
