SOURCE: power up problem
The battery is dead. I have a compaq too and when this happens it is because thebattery has run out. As stated above plug it into the wall and hopefully your battery will charge.
SOURCE: I need audio drivers for compaq Presario F500 laptop
helo ser i'm joni rahman . from indonesia plis whit deriver vga,sound,wireles, driver to all fromPresario 500 laptop
oke thengs ser
SOURCE: NOTEBOOK CPU UPGRADE
Good afternoon. Procedure of the change the processor can be very complex technically. It very simple to add some memory modules and increase productivity of yours notebook in this case.
SOURCE: Compaq Presario SR5140IL Desktop PC Xp Drivers
That computer doesnt come installed with XP you will need to find out who the original manufactuer of the devices are and download them. Intel makes it easy, they have a little tool that scans for their chipsets. You can use the vista drivers as a point of reference, for example, the Vista drivers section says it has a conexant PCI modem. If you find out the exact model number on your modem, you can go to conexant.com and download the proper driver. If they do not have it on their website, then you can find another computer that has the same hardware that was shipped out with XP and download the driver from that model. It should work without any problems. The hardest part will be finding all the model numbers for all of the devices.
