I have two radios, one seems to work ok but one can receive but dose not send
Hell ssalah,
Most of the time when one radio cannot talk to the other radio it means that the Privacy Codes are not configured properly. In order for the two radios to talk to one another they both have to be set to the same channel and Privacy Code or the Privacy Code function needs to be turned off on both radios.
The Privacy Codes can be used to keep the radios silent unless they receive a signal from another radio using the same code. This enables the radios to be used on busy channels with a minimum of interference. If Privacy Codes are turned off on one radio and turned on for the other radio, the situation you describe will occur.
Consult the user's manual for information on the Privacy Code function and either disable the function on both radios or set both radios to the same code.
Best Regards,
Ken
"Go Ahead. Use Us."
I cant talk farther than 2km all the time
