Mixer won't tilt back to remove beaters and bowls. Read that if you insert a small screwdriver in the neck slot at the base of the motor and push up while depressing the release buton on the side, the motor should release. Have tried this several times to no avail. Any suggestions. Earlene Harvey
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
This mixer is the worst piece of garbage i ever owned!!!! i just wanted to smash it today after it keep jamming up and won't tilt back up so to release my batter!! i am so mad that i am going to toss it in the garbage where it belongs!!!!!!! do not buy this, anyone!!!!!!!!!!
I thought the bowl would just release from the turning base on the mixer but can not seem to get it to release so I can remove it and pour ingredients into baking pan.
