Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C Features:
Executive spa pump wet end designed specifically for 56-frame spa motors
Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
Two speed spa motors have four sets of insulated windings for increased efficiency
56 frame spa motor for added strength, cooler operating temperature and longer motor life
Large 2-1/2 inch intake for improved flow performance and reduced noise
Large 6-1/2" diameter wet end for higher head pressure
Split capacitor, (start and run) for less energy consumption
Thermally protected to extend life expectancy of hot tub motor
Highly versatile wet end can be rotated every 90 degrees
Viton seals
Three year manufacture's warranty on spa motor and spa pump wet end
If your supply wire has 3 wires, a black, a red and a white wire, then the white wire is the neutral, it has no voltage to ground. Both the black and red wire should have 120V to ground. Between the red and black wire you find 240V. A 5hp pump would typically run on 240V, the neutral is not used.
As I'm sure you know the low speed is the filtration & heating cycle. If you've checked the terminals on the board and on the pump & there's nothing wrong. Use a voltmeter to test if each leg is getting the right voltage. If not its likely the motor is bad.
these are a hard motor to work on. i would suggest unplug it from the motherboard and un hook the plumbing and bring it to your local pool pump motor repair guy and have him test it. it just may need to be blown out with compressed air. do to dust in the start points
They no longer sell that particular model pump. The closest comparison is the new XP2E 2 HP pump which comes with the 2" inlet and outlet, but everything else is the same. It also comes with the fittings to convert from 1.5: to 2". This unit goes for about $450 on line. I also have this in stock and would sell it for the same price. Brand new in the box.
the 2" is inside diameter so you more than likely have a 2" suction/discharge. The motor is probably rated 5hp, especially since it is both a circulation and jet pump.
can you photograph the new connections for me? if you look at the connections, the neutral normally has a solid link across it, the earth will be to the frame and the other two are the high and low speed live connections.
