Go outside with the unit in the clear, and If it says "Antenna" - it means the connector for the antenna, the docking base or the antenna itself it usually bad. See if you can borrow a buddy's antenna just to see if the "Antenna" warning goes away. It could be the antenna & its connector, could be the docking base (make sure the radio is plugged in tight) or could be the radio (but usually isn't). Good luck and let me know what you find out.
