Do you have the unlock code for 8310
It's a clear and fully detailed guide on how to unlock a BlackBerry 8310 ' Curve :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
You can Unlock your Blackberry 8310 Curve with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry. get your Blackberry 8310 Curve Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
U can use the site http://www.mobileunlockguide.com/ for Blackberry mobile Unlocking Instrctions
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.
Get this Blackberry curve 8310 Imei Unlock Code .i hope this will help you :)
Good Luck.
I don't have it, but even I have that blackberry curve 8310 unlock code it will not work for your phone since blackberry unlock code is unique and one device has one unlock code. You can get your phone unlock code at third parties sites on internet.
SOURCE: I NEED MEP Code, because my Blackberry Curve 8310
you will need to try online or take the phone to a shop that unlocks blackberries
SOURCE: BB curve 8310 keyboard is not working properly
yea i have the same problem A,F,J,K,"DEL", "ENTER","ALT",X,B,V,$ these keys are not working. Last night they sudenly started working but then stopped 2 minutes later, my Blackberry wasnt dropped neither did it have any water damage. most is i have the ball removed as i await a replacement ball
SOURCE: Blackberry 8310 Network Sim Problem
$60 is much, i unlocked mine at http://blackberrymep.com just for $15 .
SOURCE: IMEI: 358263011833938 I need a
No one can provide a free unlock code, i suggest you go to BlackBerryMEP.COM and buy an unlock code, they will send Unlock Code along with instructions to enter it using your Blackberry's keypad .
I need an un-lock code for an ATT 8310 Blackberry curve
need free code for blackberry 8310 AT&T
i need a code for to unlock my blackberry curve 8310 any 1 have any ideas as to where i can purchase the code from?
