You can access Canon online support info
here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper
If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam
Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
Turn off the printer.
Remove paper from the ASF.
Gently pull the jammed paper out.
If paper is visible from the ASF, use both hands to pull the paper out slowly.
If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
The above illustration shows a PIXMA MP500.
If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
Note:
Be careful not to touch the components inside the printer.
Turn on the printer and confirm that the Alarm light is off.
(If the jammed paper remains in the printer, the paper may be automatically ejected.)
Load paper back into the ASF.
Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
Turn off the printer and disconnect the power cord and USB cable.
Remove the jammed paper slowly using the following procedure.
Open the rear cover to check if the paper is jammed.
Pull out the cassette and check if the paper is jammed inside the cassette area.
Stand the printer with the left side down, holding the document cover.
Press the tabs together and pull the green cover toward you.
Check if the paper is jammed.
(If you were not doing Duplex printing, you do not have to follow this procedure.)
Close the green cover and place the printer back to a normal position.
Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
Load paper back into the ASF or cassette.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
- Turn off the printer.
- Load the same paper type that is jammed inside the printer in portrait orientation.
- Power on the printer.
The paper stock in the ASF will automatically feed the jammed paper from the printer.
- To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
- Open the rear cover.
- Fold in four a piece of letter-sized plain paper.
- Push in the folded paper until it hits the jammed paper.
- If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
- If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
- Pull out the folded paper and close the rear cover.
- Power on the printer and confirm that the Alarm light is off.
The jammed paper should automatically eject.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
