Amana Comfort Zone 12M32PBEH Air Conditioner Logo
Posted on Nov 05, 2010
I need replacement parts for the Amana Comfort Zone Air Conditioner. I need the plastic exhaust vents that exist on the front of the air conditioner. If your are looking at the air conditioner, they are the vents on the right side.
On the Amana comfort zone air conditioner, there is a switch that says exhaust closed. Do I want the exhaust open or closed when i have the cool on the air conditioner
Hi, when you are running it in the cooling mode, leave the exhaust open to remove the condenser hot air. If you want to run just the fan to circulate the air you can close it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Amana ultron 12 seer 2 yrs old compressor does not work blows cool air not cold
is it a split system? majority of problems, lets say 95% occur during install, u may have a leak! A pinhole at that, but maybe installer missed it, your out of labor warranty, call a 3rd party contractor and have them inspect it!
Rheem criterion gas furnace
Check freon, you will need guages on the condensor, also make sure the cond, outside unit is operating
Amana Comfort Zone will not turn on.
Power coming from circut board? If yes, check the capacitor. Low voltage fuse good? Transformer good?
Rheem Criterion II air conditioner runs but it does not cool
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
Amana inwall electric heater blows cold air
Is the blower running? Sounds like unit is tripping out on high limit safety switch.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
