Canon Pixma MP500 All-In-One InkJet Printer Logo
Posted on Jun 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 6502
Changed in tanks and swapped over chips. Showed error code 6502 immediately.
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Jan 25, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1814523
Points
14613
This might work
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Luis Car
Level 1:
  • Contributor 1 Answer
  • Posted on May 01, 2020
Luis Car
Contributor
Level 1:
Answers
Questions
0
Helped
4323
Points
Hola necesito solucionar el error de mi Canon 6810.. error 6502 eh probado todo
How do clear error number 6502 on canon printer ip4900
Dear kindly reset the printer to its factory default setting.
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
32helpful
3answers
I have cannon IP3680, but from today it's making problem (Service error 6502), would u please tell me a easy way to solve the problem...
The error 6502 is an "Ink tank position sensor error". It may be that the sensor is dirty and needs cleaning. Make sure you haven't got any bright lights shining into the printer.
2helpful
2answers
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
Solution:
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
1helpful
Error code 6502
That error says it's a ink tank position error, make sure there are no paper scraps in the paper path, and you might clean the encoder strip with a q-tip and water. Make sure the carriage can move freely from one side to the other.
3helpful
Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
1helpful
Cant get ip4600 to work with new ink tanks having moved the chip
could not get anything to work so i had to buy new and original tanks with chips that solved the problem
3helpful
2answers
Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
3answers
Error 6502
1. With the printer unplugged, remove the ink cart to the right.
2. Plug in the printer, Press the POWER button, Do not release the POWER button, and then press the RESUME button twice in succession. Now release the POWER button, press the RESUME button 4 times.
3,The beeper may sound once, Then With the printer unplugged, after that reset the printer electronics ,open the printer and this process is finished.
old marine
old marine
ZJ Limited
ZJ Limited
