SOURCE: i have nokia 7210 supernova with gprs work on pc but not at mobil
change ur apn addres to www.e.pr
SOURCE: 7210 supernova got virus
Phones shouldn't get viruses. try going to your network store and see if they can fix it. If you have insureance then see if you can get it coverd. If not then you may get charged. (if your problem is fixable)
SOURCE: How do I copy sms messages from Nokia 7210 Supernova to Nokia E63
cant you save the files to memory card or just text them to phone one by onegood thing come at a cost
SOURCE: i want to install symbian SIS file on nokia 7610
you can install software or transfer files by connecting your device to a computer via a USB cable and use the Nokia PC suite to do it..download the software from internet to your computer(its free) and install them.
remember to download the exact version which suits your device as there are numerous types of pc suites.
thanks for contacting fixya!!!
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 7210c flash file and install it to C / programme files/pheonix..after finished this installation open pheonix Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
