HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
Posted on Nov 05, 2010
Hp officejet 6500 all lights are flashing and mechine says turn off and on
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2017
Points
My hp officejet 6500 flashes all its lights and tells me to turn it off and back on again.When I do this it just continues to flash and say the same thing.
  • Anonymous Feb 27, 2013
    I have the same problems.
Anonymous
Level 1:
New Friend:
  • Posted on Feb 27, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2017
Points
1 Related Answer
Anonymous
  • 52 Answers
  • Posted on Mar 30, 2011
SOURCE: hp officejet 6500 all lights
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
2answers
Hp officejet 6500 copier not starting up
Get the Diagnostic download for your 6500 from HP.com. It will trace the problem for you. Check you power supply to see if it is operational. Press all connections in tight.
1helpful
My HP officejet 6500 keeps giving me two messages 1. load paper when there is already paper and two align cartridges for 7 minutes.
before you on the unit put a single page on a tray then turn it on while initializing it feeds the paper automaticaly then print a sample page after printing put the sample page face down on the scanner then press the scan button then wait till the power on light stop blinking then youre ready now
Why does my new HP Officejet 6500 power light keep flashing about every 5 seconds ????
I thought I had a problem, but it is not a problem. The machine power light flashes when it has not been used in a while and kinda goes to sleep until you start to use it. That way it saves on power. Thanks any way. But before I would pay for help, I would throw the machine away. !!!
10helpful
3answers
Need operating instructions for HP Officejet 6500 E709. How do you send a fax?
Hi:
You can go to www.hp.com Click on the support and drivers tab, type in the model of your HP officejet 6500, and you can download the entire manual for free.
2answers
Recently bought an HP Officejet 6500. How do I
This video shows how to change ink cartridge on HP 6500 and 6500A
k24674
Grand Canyon Tech
Grand Canyon Tech
