If the Menu Display is normal. DRC module is faulty.This module is installed vertically and has a stainless steel cover, beside Tuner module. If you can do, try to remove the DRC Module,and clean its terminals with paintbrush then put it back properly, if it doesn't work replace the DRC module.
Testimonial: "thanks"
hi there just trying to work out which stainless steel module is the drc and any tips on removing it
hi i lowered all settings to zero and the screen was completely black .I found there is no contrast setting but i did move up the picture setting but still the screen is black thanks
hi, the drc moduleis often marked as BH board. near tuner module...
thanks i found it removed it gave it a clean as you said but i am still getting the same result . What would you recommend I do next?thanks for your help
replace the drc module....
called for a replacement I was told it would cost $247 and the TV would only be worth $200 any other solutions thanks
Hello
You just decrese the contrast, brightness and colour control of your TV to minimum [zero], and note which colour is predominent. Adjust the contrast to a little note the colour condition, and report to me through Fixya. Ok.
any tips on how to remove the module
