SOURCE: NUMBER OF RINGS TO ANSWER FAX
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the HP All-in-One, because you want the answering machine to
answer the phone before the HP All-in-One does. The number of rings to answer for
the HP All-in-One should be greater than the number of rings to answer for the
answering machine.
For example, set your answering machine to a low number of rings and the HP All-in-
One to answer in the maximum number of rings. (The maximum number of rings
varies by country/region.) In this setup, the answering machine will answer the call
and the HP All-in-One will monitor the line. If the HP All-in-One detects fax tones, the
HP All-in-One will receive the fax. If the call is a voice call, the answering machine will
record the incoming message.
To set the number of rings before answering from the control panel
1. Press Setup.
2. Press 4, and then press 2.
This selects Basic Fax Setup and then selects Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press or to
change the number of rings.
4. Press OK to accept the setting.
SOURCE: FAX: INcalls: how to increase the "rings to answer" number
sorry, but that is the limit for the rings to answer function of the HP all-in-one devices. some people are complaining that this does leave them with few rings to grab the phone before the answering machine picks up, as the answering machine must have at least two lower values than the HP all-in-one.
SOURCE: Increase the number of rings
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
SOURCE: Ricoh Aficio 350 change number of rings before fax answer
Can't be done..this fax can only operate on a dedicated line, and it picks up right away. Sorry.
SOURCE: Change number of rings before fax picks up.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=14444
Look in the Advanced Guide for a possible solution on page 1-8 etc.
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up
incoming faxes, set Auto Answer to On, and then set the printer to pick up
after a greater number of rings than the answering machine. For example, if the
answering machine picks up calls after four rings, then set the printer to pick
up after six rings. This way, the answering machine picks up calls first and
your voice calls are received. If the call is a fax, then the printer detects
the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the
same telephone line if you subscribe to a distinctive ring service offered by
your telephone company. This feature allows you to have multiple telephone
numbers on one telephone line. Each telephone number has a designated ring
pattern (single ring, double ring, triple ring, or double and triple ring). The
different ring patterns let you know which telephone number was dialed, and
which device you should use to answer the call.
If you do not have distinctive ring
service, then set the printer to receive faxes manually (Auto Answer Off). This
setting lets you receive both voice calls and fax calls, but works best if you
use voice mail more often. You need to turn off voice mail whenever you are
expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings section.
