Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
Posted on Jun 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Upgrading RAM Can i install a PC3200 512MB RAM on my D845GLVA board? Currently i have 128MB DDR266.
Lee A.
Level 3:
  • Master 4,472 Answers
  • Posted on Jun 14, 2008
Lee A.
Master
Level 3:
Answers
4472
Questions
0
Helped
1083177
Points
12549
Yes that should not be a problem as DDR is backward compatible with the slower speeds so the faster RAM, will just slow down to match. These are the only conditions listed so as long as the stick you have doesn't fall under this criteria you should be good.
he D845GLVA board provide the following memory features:
  • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered single-sided or double-sided DIMMs
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • DDR266/200 MHz SDRAM DIMMs only
  • Serial Presence Detect (SPD)
CAUTION:
Do not use ECC DIMMs with this board. Using ECC DIMMs could damage the board.
Integrator's Notes:
  • Registered DIMMs are not supported.
  • Double-sided x16 DIMMs are not supported.
  • If a full-length PCI add-in card is installed in PCI bus connector 1 (the PCI bus connector closest to the processor), remove the add-in card before installing or upgrading memory to avoid interference with the memory retention mechanism.
  • This board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated (currently validated up to 1.0 GB) on this board.
Note:
To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
Enjoy the increase in RAM,
Lee
2answers
What is the maximum Ram supported bu Intel 1.86
Your system has a maximum capacity of 2 GB of SDRAM - 266.0 MHz
5helpful
4answers
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
1helpful
Planning to upgrade my RAM(motherboard K7SOM + V7.5 C
According to the specifications of you PC's motherboard. It supports DDR266 PC2100 type of RAM and only a maximum of 1gb RAM can be installed. If you have 512mb total of RAM right now, it is advisable to upgrade for a better performance of your PC.
1helpful
2answers
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
3answers
Memory upgrade
Hi there.
The best memory for that motherboard is DDR SDRAM, the supported ram speed is 266 MHz • 200 MHz(maximum 2BG, 1BG in each slot)
Kingston or corsair memory running at 266MHz is my recommendation to you. Try not to buy used memory as it may not work!!
Good luck and thanks for using Fixya!!
Upgrade of Ram on Dell 8100
There are 2 possibilities here - either the slot is not working or the RAM itself.
First install the working 128MB RAM in both memory slots one after the other and ensure that both the slots are in good shape.
Next, install the other 128MB RAM in one slot and check if this is working good.
Your laptop can support a maximum memory of 512MB. If you looking for an upgrade, please call Dell Support. Even though it's little expensive and shipping takes a week, you can get a free after sales service and peace of mind. Moreover you get proper guidance from the experts.
3answers
No display
Sounds like memory is the problem to me. Try original memory, if it works, make sure you are using the proper type and speed for this motherboard.
The D845GLVA board provide the following memory features:
CAUTION:
Integrator's Notes:
Ram for intel d845glva board
System Memory Features
  • Maximum total system memory: 1 gb or 2 GB ; minimum total system memory: 64 MB
you can visit the intel site if you have any doubts here is the website below you can see the d845glva product information
http://support.intel.com/support/motherboards/desktop/d845glva/sb/CS-012941.htm
but your motherboard supports only 266 and 200 mhz RAMS
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my soution
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
2answers
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
