Harman Kardon AVR 225 Receiver Logo
Anonymous Posted on Nov 05, 2010
Hi I just Bought a LG 37LD450 TV . How do connect it to the surround sound on my Harman Kardon AVR 225 Reciver. It Looks like the only option for outputs from my TV is a Fiber Optic outlet. I Don1t see any RCA outputs> I have the optic cable Thanks Bob
  • Anonymous Nov 05, 2010
    So How do I connect it using just a DVR player with no Optic connections ?
  • Anonymous Nov 07, 2010
    Yes I found I was able to connect from my TV directly to my receiver. My 2 optic inputs in the back of my receiver were not working, Had to use the 3rd optic input in the frount
Azrael SRL
Level 3:
  • Harman Kardon Master 11,800 Answers
  • Posted on Nov 05, 2010
Azrael SRL
Level 3:
Answers
11800
Questions
0
Helped
2564684
Points
35672
Yes, you are correct: the only audio output this LG tv has is an optical/TOSLINK one. Just use a fiber cable between the tv and the HK. You use this connection to play on the HK the sound from the tv channel - they selected to use this type of connector because modern HD channels have 5.1 sound while the tv and its possible RCA output connectors are just stereo.
You connect the DVR this way: an S-Video cable and a TOSLINK between the DVR and HK , and an single RCA Composite (yellow) video cable between the HK and the LG tv.
Lee A.
Level 3:
  • Master 4,472 Answers
Lee A.
Master
Level 3:
Answers
4472
Questions
0
Helped
1083170
Points
12549
You don't output from the tv to the receiver to get surround sound. you would either output from you cable/satellite box and/or your dvd player to the surround sound via the optical. Then you can from the monitor out on the receiver to the input on the tv. If you need any further assistance please let me know.
Thank you,
Lee
  • Lee A.
    Lee A. Nov 07, 2010
    Great to hear you got it all figured out. If you found my information helpful please take a moment to accept/rate my solution accordingly.
How do to connect tv from AVR
audio out from tv to audio in on the avr
I have a Harman Kardon AVR 130 and JBL 5.1 Speakers. Bought 5 years back. I have not got the best sound quality as I feel I may not have configured the system correctly. I like to hear crisp Treble and...
if you like this is the manual http://www.google.jo/imgres?q=Harman+Kardon+AVR+130&hl=ar&safe=active&biw=1280&bih=699&tbm=isch&tbnid=LhNyGu_apsEUEM:&imgrefurl=http://fastservicemanuals.com/index.php%253Fmain_page%253Dproduct_info%2526products_id%253D1290&docid=E0j9_Qp_R6GiaM&w=298&h=382&ei=VuRHTuqxD8Kl8QOmg8CVBg&zoom=1
3helpful
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
4helpful
4answers
Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
Humming noise
Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
HK AVR 225 front display not working
thats not good power transformers in it went bad do u have it on a nice power strip or direct to wall
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
