1)Open NETWORK CONNECTIONS from CONTROL PANEL
2)Right click on the connection and select PROPERTIES.
3)There should be a tab for WIRELESS NETWORKS.
4)Find your network by name near the bottom and click REMOVE.
5)Click ADD then you will need to enter your network information manually in the window that pops up. You will need to uncheck the box that says "My key is provided automatically"
SSID is the network name.
NETWORK KEY - This is the important one. get it wrong and click OK and when you go back in to modify it Windows screws up and saves it wrong. You can enter network keys in ASCII (typed letters) or the HEX that the router converts the key into. 5 ASCII/10 Hex is for 64 bit, 13 ASCII / 26 HEX is for 128 bit. Your key must be one of these 2 lengths.
