JUMP START SYSTEM Logo
Posted on Nov 04, 2010
I need to buy wall charger for my power on board mod numer veco12p0b
Anonymous
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Nov 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
12148
Points
60
For replacement parts (charging adapters, etc.), contact Technical Support, toll free
at (866) 584-5504. Here's the owners manuel. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Vector/VEC012POB.pdf
Good luck.
O J Fisher
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 29, 2015
O J Fisher
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
899
Points
Ac adapters available thru amazon...under $10.00 incl shipping.
Search AC Adapter VECO12POB.
2helpful
Would like to purchase AC Wall Adapter for : Power on Board 450amp VECO12P0B
Call Schmacher at 1-800-524-3880 and they can set you up with a replacement. Don't be shocked at the shipped total cost. You just might want to
Your power pack will tell you what voltage wall charger you need. Where you plug one in, it will show 12v, 17v...etc. Yours is probably 12v. On the right side of the connection hole, if you see a + sign, your pack requires positive polarity when you attach an adapter. You can find universal power adapters with an adjustable output and various tips that is sure to work well with your pack. All tips will have a + sign on one side and a - on the opposite side. Just make sure you put the correct side of the tip (- or +, depending on what's on the right side of charging hole on your pack) on the same side of the wall adapter's wire connector end that has the word TIP on it or some other demarkation.
I wish you the best of luck.
What is the 3 prong outlet on the side of my chair for? Is it a charger?
If you have an on-board charger for your power chair this outlet is for your charger cord. One end of the AC cord plugs into the wall outlet and the other end plugs into the trapezoid shape outlet on the side of the chair. This is the same shaped AC cord used to power computers and other devices. You can buy one a most hardware stores and places like Radio Shack. If you are using an off board charger which plugs into the front of the joystick (round plug)to charge the chair, then you don't need to use the on-board one and you don't need another AC cord. Hope this helps.
1helpful
HI I NEED A NEW CHARGER FOR MY DVD PLAYER MODEL NUMBER PDV-705U WHERE CAN I BUY ONE FROM?
Check this out. You can buy this wall charger for home and then buy a power inverter for your vehicle and you can charge on the go. Below are links listed that can help you,
Power cord - http://cgi.ebay.com/AC-ADAPTER-DURABRAND-PDV-705-POWER-BATTERY-CHARGER-CORD_W0QQitemZ260441468047QQcmdZViewItem
power inverter - http://www.buy.com/retail/product.asp?sku=10407087&listingid=10686546&dcaid=17902
1helpful
Plug is broken
You can buy a new Durabrand Dual car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand Dual 7b portable dvd player
You can buy a new Durabrand Dual wall ac adapter by clicking on the hyperlink:
buy replacement wall ac adapter power charger cord for DURABRAND Dual 7b PORTABLE DVD PLAYER
6helpful
4answers
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
3answers
Need to replace wall charger for portable dvd -PDV-702
Well, you could bring it in to radio shack and have them check what type of tip you need, and then just buy a universal charger with that tip included.
Top Vector Vehicle Parts & Accessories Experts
Sean Wright
Sean Wright
john h
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
